Variable changed after set
ivan.ulens@vcst.be
Post by ivan.ulens@vcst.be »
Set Variable Bijlagenaam
{Bijlagenaam1}_D{Year}{MonthNo}{Day}_T{Hours}{Minutes}{Seconds}.pdf
Wait For File
{Pathnaam}\{Bijlagenaam}
Script error: E: 7/04/2021 7:49:52: File "D:\TRANSFERZONE\TEMPBARTENDER\VCST_DELIVERY_D20210407_T074952.pdf" doesn't exist.
The File "D:\TRANSFERZONE\TEMPBARTENDER\VCST_DELIVERY_D20210407_T074951.pdf" exist.
What can cause this?
Re: Variable changed after set
When you set a variable be sure to turn on "Expand variables" option
In this case RoboTask expands all variables and then set the value to variable
If this option is OFF then RoboTask assigns the value as-it-is. In this case RoboTask expands nested variables when you use the variable in other actions
You are using variables that depend on the current time. Thus, the value depends on the time of use.
Both modes can be useful for different cases
ivan.ulens@vcst.be
Thanks, now it works.
