Create XML
ivan.ulens@vcst.be
Create XML
Post by ivan.ulens@vcst.be »
I try to create a SEPA XML-File. Everything goes fine except 1 item:
<?xml version="1.0" encoding="utf-8"?><Document xmlns="urn:iso:std:iso:20022:tech:xsd:pain.001.001.03" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<CstmrCdtTrfInitn xmlns="">
<GrpHdr>
</GrpHdr>
</CstmrCdtTrfInitn>
</Document>
The 'xmlns=' on the second line is wrong. This must without attributes. In Script there aren't attributes.
Re: Create XML
XML actions use system XML engine to build and analyze XML
It seems the XML engine adds this attribute when you add child node
We'll investigate the problem how to avoid this
Re: Create XML
Already fixed.
Dowload and install fresh copy
xmlns is not a simple attribute of node. This is token of Name Space of the node
Therefore, it requires more careful handling...
Let me know about results
ivan.ulens@vcst.be
Re: Create XML
Oleg,
it looks great!
I have some questions about the policy of the software. Is it 'ok' for you if I communicate this in a mail?
regards,
Ivan
Re: Create XML
No problem
