Possible bug with Email
dcocke
Post by dcocke »
I downloaded version 2.3 today.  Was using 2.2.  Thank you for continuing to update this great product.
In the previous version there was a problem with sending Email in that if you also had attachments, the body of the Email would be blank.  This issue is resolved with 2.3.
Today, however, I am trying to send an Email with HTML in the body as well it has attachments.  The Email shows the actual html tags in the body to the recipient and not the nicely formatted body I am trying to convey.
If you send the same message without an attachment, it displays correctly.
If you send a message as text in the body and attachments, that works correctly.
Is there an additional HTML tag I could add at the beginning of the message body to get it display correctly.
By the way, I am using Outlook 2003 to receive/display the message.
Thanks,
David
Thank you for the report
