SFTP - How to Use private certificate login
mjwsr1
Post by mjwsr1 »
I am trying to use a private key file to open sftp site. I am looking for an example of how to setup a sftp logon task using a key file.
Re: SFTP - How to Use private certificate login
Look at the example below, It works on our Ubuntu Server
CatID=INTEGER|592482493
ExternalName=STRING|"Task1213"
ID=INTEGER|-1053817032
Name=STRING|"test loop (open SFTP with certificate)"
ActionID=STRING|"A_SFTP_LOGON"
Name=STRING|"SFTP Open (oleg@192.168.220.129)"
certfile=STRING|"D:\TEST\ssh-sftp\cert authentication\key20181031np.ppk"
host=STRING|"192.168.220.129"
password=STRING|"6840167175671736742767170"
port=STRING|"22"
usecertificate=STRING|"1"
username=STRING|"oleg"
ActionID=STRING|"A_SFTP_DIR"
Name=STRING|"SFTP File loop"
date1=STRING|"18991230"
date2=STRING|"18991230"
DuringMinutes=STRING|"1"
filenameonly=STRING|"0"
folder=STRING|"test/*.*"
kind=STRING|"0"
sizesave=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subfolders=STRING|"1"
timesave=STRING|"0"
varname=STRING|"FILENAME"
message=STRING|"{filename}"
But please note that you have to prepare SSH Server to accept certificate.
How to do this read here, here and here
If server rejects certificate then you can login with username and password.
