Using AC Power restore even as a trigger.
akagi82
Post by akagi82 »
Hi there.
I would like my triggering event to be when my laptop which is on (not off/asleep/hibernated) detects that AC power is restored. This is logged as an EventViewer/System/Event 105. I have attatched a screencap here of the event. Can i create a custom trigger? or does one already exist? Is there another way?
(Didn't mean to do a double post. Last one was made without a proper title.)
Re: Using AC Power restore even as a trigger.
There is OnBattery variable. It returns True if computer/laptop on battery power and False otherwise.
You can check this variable every 10 sec (for example) and do some actions if OnBattery returns True
look at my example below
CatID=INTEGER|1163085779
ExternalName=STRING|"Task1210"
ID=INTEGER|-964655590
Name=STRING|"check power"
value1=STRING|"{OnBattery}"
Name=STRING|"//Run some other task"
comment=STRING|"Run some other task"
Name=STRING|"Cyclic (every 10 sec)"
UniqueID=INTEGER|-662112480
interval=STRING|"10"
akagi82
Post by akagi82 »
Thank you for your response.
The problem with this approach is that some power fluctuations that we are trying to detect only last for a second, therefore checking every 10 seconds will likely miss it. That momentary power bump is an actionable for us as there is other equipment that require remediation after such events.
We'll add such trigger on next version.
We already work on it
