Check Status of Tasks
Hey Oleg,
Sometimes it happens (due to maintenance or testing or whatever) that a task is being disabled. This is fine, however sometimes a person forgets to re-enable it. This can have serious consequences ;)
Through the action "Task status" this can be checked, which is really cool. We have 1 specific folder in Robotask where all the tasks located in there should be enabled.
Is it possible to check a whole folder for all the tasks or do we have to specify them one by one? Do you have some good ideas?
Re: Check Status of Tasks
Look at my example
Put it into some task folder and run it
ExternalName=STRING|"Task1349"
ID=INTEGER|-1106023643
Name=STRING|"check enabled"
Name=STRING|"VB Script"
expandvars=STRING|"0"
line00000000=STRING|"c = cstr(RoboTaskApp.ExpandText(""{TaskCategoryID}""))"
line00000001=STRING|"'logmessage(c)"
line00000002=STRING|"cnt = RoboTaskApp.TaskCount"
line00000003=STRING|"txt = """""
line00000004=STRING|"for i=0 to cnt-1 step 1"
line00000005=STRING|"  c1 = cstr(RoboTaskApp.TaskInfoFolderID(i))"
line00000006=STRING|"  if c1 = c then"
line00000007=STRING|"    'logmessage(c1)"
line00000008=STRING|"    ext = RoboTaskApp.TaskInfoExtname(i)"
line00000009=STRING|"    if not RoboTaskApp.TaskEnabled(ext) then"
line0000000A=STRING|"      nam = RoboTaskApp.TaskInfoName(i)"
line0000000B=STRING|"      txt = txt + nam + VbCrLf"
line0000000C=STRING|"    end if"
line0000000D=STRING|"  end if"
line0000000E=STRING|"next"
line00000010=STRING|"RoboTaskApp.setuservariable ""disabled"", txt"
linecount=STRING|"19"
savescript=STRING|"0"
operator=STRING|"7"
value1=STRING|"{disabled}"
message=STRING|"All tasts in folder are enabled"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
message=STRING|"Disabled tasks: {eol}{disabled}"
type=STRING|"2"
Wow, that works great! Thanks!
