Does FTP File Exist?
jleask
Post by jleask »
How can I check to see if an FTP file exists or not?  I see the FileExists command, but can you use it to look for an FTP file?
The problem is I am using the script to download yesterdays file, by date, but if the file does not exist the script is breaking instead of moving on.  Any suggestions welcome :)
Thank you
--j
See example below. You can specify any file mask you want to find in FTP File Loop action.
Save text of task to file and use menu Task | Import to import into RoboTask
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|817783733
ExternalName=STRING|"Task330"
ID=INTEGER|88700190
Name=STRING|"Check file existence on FTP"
ActionID=STRING|"A_FTP_LOGON"
Name=STRING|"FTP Log On"
anonymous=STRING|"1"
host=STRING|"localhost"
passive=STRING|"0"
password=STRING|"4231738316406194034628830408604112640602242 423831112461"
port=STRING|"21"
username=STRING|"anonymous"
Name=STRING|"Show ""No files on FTP!"""
icon=STRING|"3"
msg0=STRING|"No files on FTP!"
Name=STRING|"Set variable ""FTP_EXISTS"" with value ""false"""
varname=STRING|"FTP_EXISTS"
varvalue=STRING|"false"
Name=STRING|"FTP File Loop"
filenameonly=STRING|"0"
folder=STRING|"*.*"
sizesave=STRING|"0"
subfolders=STRING|"0"
timesave=STRING|"0"
varname=STRING|"FTP_FILE"
Name=STRING|"Set variable ""FTP_EXISTS"" with value ""true"""
varvalue=STRING|"true"
Name=STRING|"Break"
value1=STRING|"{ftp_exists}"
Name=STRING|"Show ""At least one file exists on FTP"""
msg0=STRING|"At least one file exists on FTP"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
