rename file on base of folder name 2.0
jarra21
Post by jarra21 »
So im trying to use this code as a base.
https://robotask.com/forum/viewtopic.ph ... foldername
CatID=INTEGER|317955339
ExternalName=STRING|"Task372"
ID=INTEGER|1259557504
Name=STRING|"Rename files (only images2d)"
Action14=FOLDER
Action15=FOLDER
Name=STRING|"Create local variable ""FILENAME"" with value """""
varname=STRING|"FILENAME"
Name=STRING|"Set variable ""FILE"" with value ""{ExtractFileName({FileName})}"""
varname=STRING|"FILE"
varvalue=STRING|"{ExtractFileName({FileName})}"
Name=STRING|"STR Replace"
mode=STRING|"0"
replacement=STRING|"{folder}-"
source=STRING|"{file}"
substring=STRING|"img_"
variable=STRING|"NewFile"
Enabled=INTEGER|0
Name=STRING|"Show ""{FileName}"""
[Actions\Action12\Params]
msg0=STRING|"{FileName}"
msg1=STRING|"{File}"
msg2=STRING|"{Folder}"
msg3=STRING|"{NewFile}"
msgcount=STRING|"4"
Name=STRING|"Rename File"
[Actions\Action13\Params]
file0=STRING|"{FileName}"
ifexists=STRING|"1"
mask=STRING|"{NewFile}"
subdirs=STRING|"0"
[Actions\Action14]
[Actions\Action15]
Name=STRING|"Create local variable ""FILE"" with value """""
Name=STRING|"Create local variable ""FOLDER"" with value """""
varname=STRING|"FOLDER"
Name=STRING|"Create local variable ""NEWFILE"" with value """""
varname=STRING|"NEWFILE"
Name=STRING|"Create local variable ""PARENT"" with value """""
varname=STRING|"PARENT"
Name=STRING|"File Loop"
date1=STRING|"20140725"
date2=STRING|"20140725"
destvar=STRING|"FILENAME"
DuringMinutes=STRING|"1"
file0=STRING|"d:\temp\images\*.jpg"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Set variable ""PARENT"" with value ""{ExtractFileName({ExtractFilePath({FileName})})}"""
varvalue=STRING|"{ExtractFileName({ExtractFilePath({FileName})})}"
value1=STRING|"{parent}"
value2=STRING|"images2d"
Name=STRING|"Set variable ""FOLDER"" with value ""{ExtractFileName({ExtractFilePath({ExtractFilePath..."""
varvalue=STRING|"{ExtractFileName({ExtractFilePath({ExtractFilePath({FileName})})})}"
My folder structure is E:\ArchivetoOptical\{folder}\*.mxf
my goal is to have the foldername get pasted on to the .MXF file so for this example i want the .MXF to be named 0ba7415c2b924ef48224f2cc6e4360ce_4PM Focus Text and Drive VO 1005.mxf
or if possible would be 0ba7415c2b924ef48224f2cc6e4360ce_4PM Focus Text and Drive VO 10.05.mxf with the added period.
Re: rename file on base of folder name 2.0
Do you want to add foldername to the filename? Do I understood correctly?
If so then look at my example below
CatID=INTEGER|1163085779
ExternalName=STRING|"Task220"
ID=INTEGER|1338142634
Name=STRING|"Rename file (add foldername)"
date1=STRING|"20200709"
date2=STRING|"20200709"
file0=STRING|"E:\ArchivetoOptical\*.mxf"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Set variable ""FOLDERNAME"" with value ""{ExtractFileName({ExtractFilePath({FileName})})}"""
varname=STRING|"FOLDERNAME"
Name=STRING|"Set variable ""NEWFILENAME"" with value ""{foldername}.{ExtractFileName({filename})}"""
varname=STRING|"NEWFILENAME"
varvalue=STRING|"{foldername}.{ExtractFileName({filename})}"
ifexists=STRING|"0"
mask=STRING|"{NewFilename}"
subdirs=STRING|"0"
jarra21
Post by jarra21 »
Hey what you sent me worked 100%! Thank you so much! What kind of code would i need to add to make the renamed file move to my ArchivetoOptical folder? i tried the copy/move file function with E:\ArchivetoOptical\*\*.mxf but that does not seem to work. If its not to hard could you also help me with deleting the folder after the file has moved.
Thanks for your help!
