Send email with attached PDF File Monitor
Charlyro222
Post by Charlyro222 »
Hi:
I´d like to know if there is an easy way to File Monitor a folder and as soon as a file with wilcard like *Portada*.PDF send an email with the attached file.
After that delete all files in folder.
Thank´s in advance
Re: Send email with attached PDF File Monitor
I think that you can create the task like this (see below)
CatID=INTEGER|1163085779
ExternalName=STRING|"Task1225"
ID=INTEGER|161499709
Name=STRING|"Monitor portada files"
Name=STRING|"Set variable ""FOLDER"" with value ""c:\incoming"""
varname=STRING|"FOLDER"
varvalue=STRING|"c:\incoming"
Name=STRING|"File Loop"
date1=STRING|"20200629"
date2=STRING|"20200629"
destvar=STRING|"FILENAME"
DuringMinutes=STRING|"1"
file0=STRING|"{folder}\*portada*.pdf"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
Name=STRING|"Send Email"
attach0=STRING|"{filename}"
attachcount=STRING|"1"
auth=STRING|"0"
charset=STRING|"iso-8859-1"
from=STRING|"user@host.com"
host=STRING|"host.com"
html=STRING|"0"
msg0=STRING|"Look PDF in attachment"
password=STRING|"2591325713264762545426990"
port=STRING|"25"
priority=STRING|"1"
receipt=STRING|"0"
SSL=STRING|"0"
subject=STRING|"New portada file"
to=STRING|"user@destination.com"
xmailer=STRING|"RoboTask"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
file0=STRING|"{filename}"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
Name=STRING|"File Monitor"
UniqueID=INTEGER|-1104217145
chg=STRING|"1"
chga=STRING|"1"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"0"
folder1=STRING|"c:\incoming"
foldercount=STRING|"1"
incmask=STRING|"*portada.pdf"
interval=STRING|"60"
listmode=STRING|"1"
mon_files=STRING|"1"
mon_folders=STRING|"0"
new=STRING|"1"
pass=STRING|"0"
passmode=STRING|"1"
required=STRING|"0"
saveresults=STRING|"0"
subfolders1=STRING|"0"
