File loop on network location
brainbridge
Post by brainbridge »
Hi all,
I have a problem with robotask concerning accessing files on a network location. \\serverxx\... or \\10.10.0.10\...
Robotask isn't finding any files.
If I change this to a local location everything is working.
CatID=INTEGER|0
ExternalName=STRING|"Task3"
ID=INTEGER|-504778660
Name=STRING|"testing"
Name=STRING|"File Loop"
date1=STRING|"20200611"
date2=STRING|"20200611"
destvar=STRING|"OK"
DuringMinutes=STRING|"1"
file0=STRING|"\\serverxx\kmo\testscript\*.xlsx"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
message=STRING|"{OK}"
Name=STRING|"Create File List (variable: OK2)"
After=STRING|"0"
aftercount=STRING|"0"
AfterLine=STRING|"0"
Before=STRING|"0"
beforecount=STRING|"0"
BeforeLine=STRING|"0"
destfile=STRING|"OK2"
destvar=STRING|"OK2"
file0=STRING|"\\serverxx\KMO\testscript\*.xlsx"
savetofile=STRING|"0"
savetovar=STRING|"1"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"1"
Any tips to find the solution?
Regards
Stephan
Re: File loop on network location
I created the similar task (see below). It works
CatID=INTEGER|1075658632
ExternalName=STRING|"Task1194"
ID=INTEGER|1827985836
Name=STRING|"file loop on network"
destvar=STRING|"FILENAME"
file0=STRING|"\\192.168.2.38\diskd\Temp\*.*"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
message=STRING|"{FileName}"
Name=STRING|"Create File List (variable: aaa)"
After=STRING|"0"
Before=STRING|"0"
destvar=STRING|"aaa"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"1"
message=STRING|"{aaa}"
Of course network resource must be available in user session. Otherwise you will get an empty list
Another one question: where do you run this task? In application mode or under system service mode?
brainbridge
Hi Oley,
Thanks for your feedback.
I am running as a remote task so u supposse system service mode.
I also test it with the option 'logon task as user (for NT Service mode only)'.
Afther changing the service to 'run as a user' and not local system everyhting is working :)
Thx!
Another small question
The option -> 'logon task as user (for NT Service mode only)'.
Is this reffering to the account you specify under the Robotask service manager, tab 'logon Parametres'?
Kind regards,
Stephan
By default system service can't access network resources.
There are two ways to solve this problem
  • Logon task as some user
    RoboTask service will work under SYSTEM account but it can run task with specified credentials.
    • Specify login parameters in RoboTask Service manager (Logon parameters tab)
      Turn ON "Logon task as user" (Task editor -> Advanced tab). This checkbox is ON by default. You can turn it off. In this case the task will be performed with SYSTEM credentials.
  • Logon system service as user
    Go RoboTask service manager -> Service Setup tab -> Service configuration button.
    You can specify valid user account and system will start service under specified credentials.
    But please note that the user must have Logon as a service system security policy. (Local security policy->Local policies->User rights assignment->Log on as a service)
Both methods have their advantages and disadvantages.
