TaskNumByExternalName service task
manxasp
Post by manxasp »
Hiho.
How to get Task Num when the task are running in Robotask Service?
When i use:
extName = "Task18"
Num = RoboTaskApp().TaskNumByExternalName(extName)
LogMessage(num)
____
Log = -1
when i try with user local task
extName = "Task155"
LogMessage(num)
____
Log = 1
Re: TaskNumByExternalName service task
If you want to retrieve TaskNum from service task have to run this script on service.
RoboTask application and RoboTask service are different instances of RoboTask. RoboTask service is the separate process with own tasks.
TaskNumByExternalName method retrieve TaskNum from local set of tasks only.
