collecting info
collecting info
Post by 5243 »
I have a question. I'd like to have a task that only collects error warnings from other tasks.
example:
task01 runs 1x per minute
task02 runs 1x per minute
task03 runs 1x per minute
then task 4 runs 1x per hour, and will send 1 report if there are errors in task 1,2 or 3.
Mailing the info is not a problem, collecting the errors information from different tasks and then combine them in 1 text file, is the problem.
is this possible?
Re: collecting info
You can extract all error and warning messages from log files of these tasks by using regular expressions
Look at my small example below.
Just specify necessary log files in 1-st step
ExternalName=STRING|"Task231"
ID=INTEGER|-2006886938
Name=STRING|"collect errors and warnings form logs"
Name=STRING|"Set variable ""LOGFILES"" with value ""20B41AB4.log{EOL}2430EFAC.log"""
varname=STRING|"LOGFILES"
varvalue=STRING|"20B41AB4.log{EOL}2430EFAC.log"
Name=STRING|"Run ""collected.txt """
ifnonzero=STRING|"0"
program=STRING|"{TempDir}\collected.txt"
runas=STRING|"0"
wait=STRING|"0"
Name=STRING|"Set variable ""TEXT"" with value """""
varname=STRING|"TEXT"
Name=STRING|"Text Loop"
destvar=STRING|"FILENAME"
line0=STRING|"{LogFiles}"
sourcetext=STRING|"1"
Name=STRING|"Set variable ""TEXT"" with value ""{Text}{EOL}*****************************{EOL}Log File: {FileName}"""
varvalue=STRING|"{Text}{EOL}*****************************{EOL}Log File: {FileName}"
ActionID=STRING|"A_REGEXP_LOOP"
Name=STRING|"RegExp Loop"
anchored=STRING|"0"
extended=STRING|"0"
file=STRING|"{LogFolder}\{filename}"
linecount=STRING|"0"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"(?im)^(e\s|w\s).+$"
savelengths=STRING|"0"
saveoffsets=STRING|"0"
singleline=STRING|"0"
ungreedy=STRING|"0"
useexternal=STRING|"1"
variable=STRING|"line"
Name=STRING|"Set variable ""TEXT"" with value ""{Text}{EOL}{line(0)}"""
varvalue=STRING|"{Text}{EOL}{line(0)}"
Name=STRING|"Create text file {TempDir}\collected.txt"
encode=STRING|"0"
fileexists=STRING|"0"
filname=STRING|"{TempDir}\collected.txt"
line0=STRING|"{text}"
suppress=STRING|"1"
Re: collecting info
Post by 5243 »
thank you Oleg for your quick response!
This task is almost all right, the only thing what is missing is, at the moment the log files are collected, the log files need to be emptied, is this perhaps also possible?
ps....maybe emptying the log file is not a good option?
maybe it's better to get only the error info from the last hour?
Re: collecting info
look at the 2-nd version of the task
You have to extract log time from each record and calculate the time difference
Put the log list into step #1
Put the max time delta into step #2 (delta must be in minutes. 1 hour = 60 minutes)
ExternalName=STRING|"Task332"
ID=INTEGER|2003726288
Name=STRING|"collect errors and warnings form logs (ver2)"
ToLog=INTEGER|2
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
Action17=FOLDER
Action18=FOLDER
Action19=FOLDER
Action20=FOLDER
Action21=FOLDER
Action22=FOLDER
Action23=FOLDER
value1=STRING|"{TimeFound}"
ActionID=STRING|"A_TIMEDIFFERENCE"
Name=STRING|"Time Difference"
datetime1=STRING|"{dt(1)}"
datetime2=STRING|"{DateTime}"
format=STRING|"1"
valuekind=STRING|"0"
varname=STRING|"logtime"
Name=STRING|"If Then // newer than 60 minutes"
[Actions\Action12\Params]
operator=STRING|"4"
type=STRING|"1"
value1=STRING|"{logtime}"
value2=STRING|"{delta}"
Name=STRING|"RegExp Match"
[Actions\Action13\Params]
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"{Line}"
pattern=STRING|"(?i)^(e\s|w\s).+$"
savesubexpression=STRING|"0"
subexpressionpos=STRING|"0"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"errorfound"
[Actions\Action14]
Name=STRING|"If Then //is error or warning"
[Actions\Action14\Params]
value1=STRING|"{ErrorFound}"
[Actions\Action15]
Name=STRING|"Set variable ""TEXT"" with value ""{Text}{EOL}{line}"""
[Actions\Action15\Params]
varvalue=STRING|"{Text}{EOL}{line}"
[Actions\Action16]
[Actions\Action17]
[Actions\Action18]
[Actions\Action19]
Name=STRING|"Set variable ""DELTA"" with value ""60"""
varname=STRING|"DELTA"
varvalue=STRING|"60"
[Actions\Action20]
[Actions\Action21]
[Actions\Action21\Params]
encode=STRING|"0"
suppress=STRING|"1"
[Actions\Action22]
[Actions\Action22\Params]
runas=STRING|"0"
wait=STRING|"0"
[Actions\Action23]
[Actions\Action23\Params]
message=STRING|"*** finish ***"
message=STRING|"*** begin ***"
Name=STRING|"Text Loop // by file list"
message=STRING|"Process file {filename}"
Name=STRING|"Text Loop // by logfile"
destvar=STRING|"LINE"
sourcetext=STRING|"0"
Name=STRING|"RegExp Match //extract time"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"{line}"
pattern=STRING|"^.\s(.+):\s"
savesubexpression=STRING|"1"
subexpressionvar=STRING|"dt"
ungreedy=STRING|"0"
variable=STRING|"timefound"
Re: collecting info
Post by 5243 »
Hi Oleg,
this is a very good example!
Thank you so much for this.
The only problem is that the search function in the text lines is very processor intensive and takes a very long time.
In this project, processor speed very important.
is there perhaps also the possibility to copy the entire log file
save and/or send it, and then give a 'clear log' command?
In this case, this would be so much faster, and less processor intensive!
Re: collecting info
... and then give a 'clear log' command?
There is no such command
How many lines in you log files?
I think that there is no sense to use more than 10000 lines
You can change it in RoboTask options (menu Options->Settings)
Re: collecting info
Post by 5243 »
Hi, Oleg,
I've checked all my log files and I saw that there's one log file that gave a warning every second.
So that is al lot of text in one hour.
I deleted this log file from the task, and now its working perfect!!
Thank you!
5243
Re: collecting info
Post by 5243 »
Hi Oeleg,
I have just one more question, is it also possible to see only the last two line from te log file????
Re: collecting info
Look at the example below:
ExternalName=STRING|"Task1146"
ID=INTEGER|1613239958
Name=STRING|"Show last 2 lines from the text"
Name=STRING|"Set variable ""FILENAME"" with value ""D:\Temp\file1.txt"""
varname=STRING|"FILENAME"
varvalue=STRING|"D:\Temp\file1.txt"
ActionID=STRING|"A_TXT_NUMBEROFLINES"
Name=STRING|"TXT Number of Lines"
external=STRING|"1"
filename=STRING|"{filename}"
variable=STRING|"num"
incement=STRING|"-1"
vaiable=STRING|"num"
external=STRING|"1"
linenum=STRING|"{num}"
variable=STRING|"line1"
incement=STRING|"1"
external=STRING|"1"
variable=STRING|"line2"
Name=STRING|"Show ""Last 2 lines:"""
msg0=STRING|"Last 2 lines:"
msg1=STRING|"{Line1}"
msg2=STRING|"{Line2}"
msg4=STRING|"Text contains {num} lines"
msgcount=STRING|"5"
Re: collecting info
Post by 5243 »
Thank you!
You are always super helpful, you always give a super service!
