reading info from a file name
benny.davidovich
Post by benny.davidovich »
I have pdf files that have some info that i want to get from them, the info location is between the first left char and until the first space.
file name expample:
40377 xxx yyy n 98.pdf i want to get the 40377
11 dfdf er 44.pdf i want to get the 11
0001244 frtr dd.pdf i want to get 0001244
what is the correct function for do it?
Thanks
Benny
Re: reading info from a file name
Look at my small example below
You can determine position of 1-s space and extract sub-string before this position.
ExternalName=STRING|"Task212"
ID=INTEGER|-1441412904
Name=STRING|"get 1-st number from the name"
Name=STRING|"Text Loop"
destvar=STRING|"FILENAME"
line0=STRING|"40377 xxx yyy n 98.pdf"
line1=STRING|"11 dfdf er 44.pdf"
line2=STRING|"0001244 frtr dd.pdf"
line3=STRING|"TheNameWithoutSpace.pdf"
linecount=STRING|"4"
sourcetext=STRING|"1"
ActionID=STRING|"A_STR_POS"
Name=STRING|"STR Pos"
from=STRING|"1"
search=STRING|"{Chr(32)}"
source=STRING|"{filename}"
variable=STRING|"p"
type=STRING|"1"
value1=STRING|"{p}"
value2=STRING|"0"
Name=STRING|"Show ""Name: {filename}"""
icon=STRING|"0"
msg0=STRING|"Name: {filename}"
msg2=STRING|"Spase is not found!"
msgcount=STRING|"3"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"STR Extract"
amount=STRING|"{p}"
from=STRING|"1"
source=STRING|"{FileName}"
variable=STRING|"num"
msg2=STRING|"extracted string: {num}"
msgcount=STRING|"3"
benny.davidovich
Thanks Oleg,
Now i have some other problem, sometime the numbers are at the beginning and some time at the end, for example:
40377 06.1.28 petter maxim
peter maxim 06.1.28 40377
and if it possible to take only numbers and not other char?
Thanks
benny.davidovich wrote: want to get from them, the info location is between the first left char and until the first space
Define task conditions more correctly, please.
Rukbunker wrote:It should be possible with Regex...
Yes, of course you have to use regular expressions in this case
Look at my example below, it works
ExternalName=STRING|"Task220"
ID=INTEGER|-1803130410
Name=STRING|"get the number from the file name"
line4=STRING|"40377 06.1.28 petter maxim.pdf"
line5=STRING|"peter maxim 06.1.28 40377.pdf"
line6=STRING|"peter maxim 40377 06.1.28.pdf"
linecount=STRING|"7"
Name=STRING|"Show ""Name: ""{filename}"""""
icon=STRING|"0"
msg0=STRING|"Name: ""{filename}"""
msg2=STRING|"expression is not found!!"
msgcount=STRING|"3"
Name=STRING|"Set variable ""NAME"" with value ""{ExtractFileNameNoExt({filename})}"""
varname=STRING|"NAME"
varvalue=STRING|"{ExtractFileNameNoExt({filename})}"
Name=STRING|"RegExp Match"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"{name}"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"^(\d+)\s|\s(\d+)\s|\s(\d+)$"
savesubexpression=STRING|"1"
singleline=STRING|"0"
subexpressionpos=STRING|"0"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"found"
value1=STRING|"{found}"
Name=STRING|"Set variable ""EXPR"" with value ""{expr(0)}"""
varname=STRING|"EXPR"
varvalue=STRING|"{expr(0)}"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"{expr}"
pattern=STRING|"(\d+)"
ungreedy=STRING|"0"
Name=STRING|"Set variable ""NUM"" with value ""{expr(1)}"""
varname=STRING|"NUM"
varvalue=STRING|"{expr(1)}"
Name=STRING|"Show ""File Name: {filename}"""
msg0=STRING|"File Name: {filename}"
msg1=STRING|"Name only: {name}"
msg3=STRING|"extracted string: {num}"
msgcount=STRING|"4"
Name=STRING|"Else"
