Cannot create CEF object with message
photofrog
Post by photofrog »
Hi. I am getting the below messages quite frequently when trying to access URLs. I was using the Web Plugin before without an issue before.
Have any ideas on what to try here? Thank you.
David
E: 5/6/2020 10:30:21 AM: Can not create CEF object with message: CEF Initialization failed!
E: 5/6/2020 10:30:21 AM: Timeout is over
E: 5/6/2020 10:30:21 AM: An error occurred. Step #27 (CEF Web Page Information).
E: 5/6/2020 10:30:21 AM: Task execution is aborted
Re: Cannot create CEF object with message
Give me the full log file of the task, please.
Maybe the computer has high load at this moment: processor or intensive disk operations. Or both.
photofrog
Post by photofrog »
See attached. Thanks.
719F17AA.log.zip
(22.74 KiB) Downloaded 1324 times
I need full logging for investigation
Your log contains only your custom messages and errors.
Where are information messages? I can say nothing...
The only thing - error happened
photofrog
Post by photofrog »
Sry. That is what I thought but I don't see where to give more detailed logging.
Where do I turn that on or what log do you want?
FYI. I did shut down anything taking up CPU to get more CPU Idle, then ran the task and it worked.
Thanks.
David
Open the task in task editor, go to Advanced tab and set Log Level to All messages
Thank you for the information
