Copy Folder Structure
csonon
Post by csonon »
Hello -
I am trying to copy a folder structure that contains no data (used as a template for creating projects). I cannot find a way to do this and I want to avoid having to do a "Create Folder" for each instance as there are about 40 folders. I tried creating a ZIP package and using extract, I tried the Synchronize Folders feature with the Sync an Empty Folder option and Unidirectional and have not been able to get this to work. I am sure there has to be a more efficient way than "Create Folder" 40 times?
Re: Copy Folder Structure
You can use Synchronize Folders action.
Use a nonexistent file mask (for example: nofile.noext ) and turn ON the options:
  • Include subfolder
  • Sync an empty folders
Look at the small example below.
ExternalName=STRING|"Task171"
ID=INTEGER|434300207
Name=STRING|"Synchronize Folders..."
ActionID=STRING|"A_FOLDER_SYNCHRONIZE"
Name=STRING|"Synchronize Folders"
clearro=STRING|"0"
details=STRING|"0"
detailstovar=STRING|"0"
exact=STRING|"0"
foder1=STRING|"d:\temp"
foder2=STRING|"e:\test"
hidden=STRING|"0"
howsync=STRING|"1"
includeempty=STRING|"1"
includemask=STRING|"nofile.noext"
subdir=STRING|"1"
system=STRING|"0"
twosecprecision=STRING|"1"
This task creates the exact copy of folder structure without files
csonon
Post by csonon »
Perfect! That worked. Thank you!
