Problems copy/Move files
arteta2k
Post by arteta2k »
Hello, i'm a reseller of robotask from Spain. We have a problem with one of our coustomers.
They have a rip software that export PDF files to another folder. The rip first create the end file with 0kb and this file is growing. The final file can be any size from 20 Mb to 1,2,3...Gb and the computer can take a long and variable time to create the file.
They have a Cyclic task that every 100 seconds move this file to another computer way network that make a conversion of the PDF file and the problem is that the robotask try to move the incomplete file every 100 seconds and move bad files to the another computer making this crash.
How can we make that robotask detect that the file is complete and move it at that time?
Thanks
Re: Problems copy/Move files
Look at {IsFileFree(<full_file_name>)} variable.
Returns False if the file is occupied by another process. For example if file being copied at this moment.
If file is completely free it returns True
Also look at small example below
ExternalName=STRING|"Task170"
ID=INTEGER|685754357
Name=STRING|"check the file"
Name=STRING|"Set variable ""FILENAME"" with value ""D:\Temp\Test.pdf"""
varname=STRING|"FILENAME"
varvalue=STRING|"D:\Temp\Test.pdf"
value1=STRING|"{IsFileFree({FileName})}"
Name=STRING|"Show ""You can copy this file"""
msg0=STRING|"You can copy this file"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""File is NOT FREE!!!"""
icon=STRING|"3"
msg0=STRING|"File is NOT FREE!!!"
Also you can use Wait for file action to wait until the file will be available
