Please help me I find this very frustrating , i have read the online help and this should work
all i want to do is get a variable from a line of text, why is it so hard?
only want a single line
- Attachments
- errorrobo.jpg (204.37 KiB) Viewed 5447 times
Re: only want a single line
Look at my example, it works
You have to specify variable only without braces in 1-st step The task example. Save the text of the task to a file and use menu Task->Import to import the task into RoboTask.
ExternalName=STRING|"Task77"
ID=INTEGER|1151108234
Name=STRING|"TXT Extract Line..."
external=STRING|"1"
filename=STRING|"D:\Temp\file1.txt"
linecount=STRING|"0"
linenum=STRING|"1"
variable=STRING|"hash"
Name=STRING|"Show ""{hash}"""
msg0=STRING|"{hash}"
