Upgrade failed, but downgrade as well
-edit-
Problem has been solved, please delete this topic!
Screenshot
Screenshot
Re: Upgrade failed, but downgrade as well
Your key is valid up to version 7.5 (see your screenshot)
In order to install some previous version you have to uninstall your current version first, because installation program doesn't replace newer files.
Control panel -> Programs and features and uninstall RoboTask.
Next, you can install any previous version without problem.
>>>You can find all previous versions here<<<
