Assign test back to clipboard?
kunkel321
Post by kunkel321 »
It looks like I can assign the text contents to a variable by way of Set Variable OldClipBrd with {ClipBoardContent}.
But then later can I put that text back on the clipboard?
I tried it like in the img, but it didn't seem to work.
Re: Assign test back to clipboard?
All system variables are read-only. So you can read the value but can not write new value.
In other words, system variables are some functions that return a value upon request.
To set new clipboard content use Put Text action
kunkel321
Post by kunkel321 »
Oleg wrote:To set new clipboard content use Put Text action
That makes sense. Thanks Oleg. Hey can you (or somebody) please test this script? I think I might not be using Put Text correctly(?)
Assign a hotkey for a trigger. Then before running the Task, makes sure some original text is on your Windows clipboard. Then select a different second string of text, and activate the script. It should show three dialogs:
1. The original clipboard text,
2. Then the different second string,
3. Then the original clipboard text again.
Steps 1 and 2 work as expected, but step three is showing {myVar} again.
CatID=INTEGER|327331060
ExternalName=STRING|"Task3"
ID=INTEGER|2005690827
Name=STRING|"Clipboard Tester"
Name=STRING|"Show ""Stuff first on clipboard: {ClipBoardContent}"""
msg0=STRING|"Stuff first on clipboard: {ClipBoardContent}"
Name=STRING|"Set variable ""OLDCLIPBRD"" with value ""{ClipBoardContent}"""
varname=STRING|"OLDCLIPBRD"
varvalue=STRING|"{ClipBoardContent}"
Name=STRING|"Copy"
mode=STRING|"1"
Name=STRING|"Get Text"
variable=STRING|"MyVar"
Name=STRING|"Show ""Stuff just copied to clipboard: {MyVar}"""
msg0=STRING|"Stuff just copied to clipboard: {MyVar}"
Name=STRING|"Put OldClipBrd back on Clipboard"
line0=STRING|"{OLDCLIPBRD}"
sourcetext=STRING|"1"
Name=STRING|"Show ""Original stuff on clipboard? {ClipBoardContent}"""
msg0=STRING|"Original stuff on clipboard? {ClipBoardContent}"
Name=STRING|"Shift+Ctrl+Alt+T"
UniqueID=INTEGER|-581013023
hotkey=STRING|"57428"
corrected task below.
ExternalName=STRING|"Task216"
Name=STRING|"Clipboard Tester (v2)"
Name=STRING|"Show ""Stuff first on clipboard: {#ClipBoardContent}"""
msg0=STRING|"Stuff first on clipboard: {#ClipBoardContent}"
Name=STRING|"Set variable ""OLDCLIPBRD"" with value ""{#ClipBoardContent}"""
varvalue=STRING|"{#ClipBoardContent}"
Name=STRING|"Copy"
mode=STRING|"1"
Name=STRING|"Show ""Stuff just copied to clipboard: {#MyVar}"""
msg0=STRING|"Stuff just copied to clipboard: {#MyVar}"
line0=STRING|"{#OLDCLIPBRD}"
Name=STRING|"Show ""Original stuff on clipboard? {#ClipBoardContent}"""
msg0=STRING|"Original stuff on clipboard? {#ClipBoardContent}"
UniqueID=INTEGER|1972981168
  1. Look at the step #2.
    You should turn on Expand Variable now option
  2. Look at the steps #1, #2, #5, #6, #7
    You should use # symbol before variable name. This is necessary to limit the depth of expanding variable. >>Read here please about this<<
    The problem is that the variable contains the text with other variables it can break the original text.
    Pay attention that step#4 copies to clipboard the text of current task. The task contains variable OLDCLIPBRD which already contains some other text. This text can contain variables too, and so on
kunkel321
Post by kunkel321 »
Thanks for this by the way Oleg -- I'm only now having time to work on my project again. :D
