STR Replace `n
kunkel321
STR Replace `n
Post by kunkel321 »
Hi There, I'd like to find-and-replace a "new line character" in a string of text. I think that's what you call it?
For example given this
Fib
Wap
Ding
Bar
I'd like to find `n and replace it with | and the result would be:
Fib|Wap|Ding|Bar
I tried
`n
\n
<New Line>
<Enter>
None of them work.
Re: STR Replace `n
Look at my example
ExternalName=STRING|"Task170"
ID=INTEGER|-1044006952
Name=STRING|"replace ""end-of-line"""
Name=STRING|"Set variable ""TXT"" with value ""Fib{EOL}Wap{EOL}Ding{EOL}Bar"""
varname=STRING|"TXT"
varvalue=STRING|"Fib{EOL}Wap{EOL}Ding{EOL}Bar"
Name=STRING|"Show ""{txt}"""
msg0=STRING|"{txt}"
Name=STRING|"STR Replace (remove #13 symbol)"
mode=STRING|"0"
source=STRING|"{txt}"
substring=STRING|"{Chr(13)}"
variable=STRING|"txt"
Name=STRING|"STR Replace (#10 -> ""|"")"
mode=STRING|"0"
replacement=STRING|"|"
substring=STRING|"{Chr(10)}"
msg0=STRING|"{txt}"
kunkel321
Re: STR Replace `n
Post by kunkel321 »
Ah yes! Now that I think of it, the corresponding character in Excel is CHAR(13), so this makes sense. Thanks Oleg!
EDIT: Strange how is takes two steps. Chr(13) to Chr(10) to "|." A bit kludgy, but that's okay--It seems to work fine. :geek:
