Evaluation confusion
rtwright68
Post by rtwright68 »
I am assigned data from a SQL Query to a variable named ORDERED_SQFT (it is just numbers i.e. 1453534.879)
I want to take that value and divide by 1000 (multiply by .001)
I created an EVALUATE action that looks as follows:
Expression to Evaluate:
.001*{ORDERED_SQFT}
Assign to Variable:
ORDERED_MSF
It fails with: Error in expression ".001*"
Not sure what I am missing?
Re: Evaluation confusion
It seems the variable ORDERED_SQFT contains the empty value
check it please. You can output the value to the task log
I test this in simple example, it works
CatID=INTEGER|1251730006
ExternalName=STRING|"Task160"
ID=INTEGER|558365431
Name=STRING|"test evaluate"
Name=STRING|"Set variable ""MYVAR"" with value ""1453534.879"""
varname=STRING|"MYVAR"
varvalue=STRING|"1453534.879"
Name=STRING|"VB Evaluate"
expression=STRING|".001*{MyVar}"
linecount=STRING|"0"
loadfromfile=STRING|"1"
variable=STRING|"res"
Name=STRING|"Show ""{res}"""
msg0=STRING|"{res}"
