Have regex only return one item?
kunkel321
Post by kunkel321 »
Hi there,
The Task at the bottom is meant to locate the time in a string of text, then save it to a variable for re-use. I don't want it to get all of the subexpressions though... I only want it to get "2:45pm." Ideas how to do this?
EDIT: Actually, it looks like checking the "No AutoCapture" box is the answer...
Second Edit: Or maybe not. (See Oleg's reply)
RoboTask: TimeGetter
Time = 2:45pm,2:45pm,2:4,pm,pm
OK
fyi This was made from copying Oleg's IP Address task :- }
CatID=INTEGER|327331060
ExternalName=STRING|"Task3"
ID=INTEGER|1840723945
Name=STRING|"TimeGetter"
Name=STRING|"RegExp reTime Match"
anchored=STRING|"0"
case=STRING|"1"
extended=STRING|"0"
line00000000=STRING|"The time will be 2:45pm next Wednesday."
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"\b(([0-2]?[0-9]:[0-5])[0-9](\s?(pm|am|p|a)?)|[12]?[0-9](pm|am|p|a))\b"
savesubexpression=STRING|"1"
singleline=STRING|"0"
subexpressionpos=STRING|"0"
subexpressionvar=STRING|"reTime"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"found"
value1=STRING|"{found}"
Name=STRING|"Show ""Time = {reTime}"""
msg0=STRING|"Time = {reTime}"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""Not found."""
icon=STRING|"0"
msg0=STRING|"Not found."
Name=STRING|"Shift+Ctrl+Alt+C"
UniqueID=INTEGER|1635334739
hotkey=STRING|"57411"
Re: Have regex only return one item?
I made some corrections in your task. Test it please.
When you save found expression into variable the RegExp Match action saves expression as comma-separated string: a zero element is the whole expression. The next elements are subexpressions in order.
Each expression in round brackets "(...)" is a sub-expression.
Test the task. Save the text of the task to a file and use menu Task->Import to import the task into RoboTask.
Do not forget to enable the task after importing. I changed the step#3 only ( {reTime} --> {reTime(0)} )
CatID=INTEGER|1075658632
ExternalName=STRING|"Task1137"
Name=STRING|"TimeGetter (corrected)"
anchored=STRING|"0"
case=STRING|"1"
extended=STRING|"0"
ungreedy=STRING|"0"
Name=STRING|"Show ""Time = {reTime(0)}"""
msg0=STRING|"Time = {reTime(0)}"
Name=STRING|"Else"
icon=STRING|"0"
UniqueID=INTEGER|-1779785127
kunkel321
Post by kunkel321 »
Thanks Oleg! I actually did read that part of the manual... I guess I just needed an example before I could understand it. :mrgreen:
