⚠ BUG | plugin e-mail, "a0013 BAD FETCH not allowed now"
ArcGabriel
Post by ArcGabriel »
The plugin email randomly returns the error "a0013 BAD FETCH not allowed now."
Expected behavior
Daily email delivery through a Gmail account (smtp.gmail.com) in HTML format
Actual behavior
randomly, the plugin eMail.rtp randomly returns the error
Callback
  • Code: Select all
    ☒ 23/02/20 03:00:11: a0013 BAD FETCH not allowed now.
    ☒ 23/02/20 03:00:11: Failed execute 'ExecAction with exception: a0013 BAD FETCH not allowed now.' (C:\Program Files (x86)\RoboTask\Plugins\eMail\eMail.rtp)
    ☒ 23/02/20 03:00:11: An error occurred. Reconfigure this step.
    ☒ 23/02/20 03:00:11: Task execution is aborted
Environment
  • SO: Windows 10 Professional
  • RT: 7.6.3.990 - business licence BD05D1DC
Workaround
  • to change the 'mode' to SSL and port 465
  • to change the 'mode' to TLS and port 587
  • to delete the email action and to add new email action
  • to create a new task w a new email action
Re: ⚠ BUG | plugin e-mail, "a0013 BAD FETCH not allowed now"
Expected behavior
Workaround
Probably I don't understand you. SMTP protocol is using in Send email action. But this action is in another plugin (Internet)
Gmail uses ports 465 and 587 in SMTP protocol only.
But I see this in error message
But email plugin doesn't contain actions with SMTP protocols. And I don't see what action raises this error.
ArcGabriel
Hello Oley,
Sorry for my previous explanation,
I was reviewing the task according to your comments, indeed, the action that has been failing is the 'IMAP Mail Loop'. My mistake was due to a previous issue, this is another case. I updated the issue form and attachment a screenshot as reference.
Thanks you very much Oley.
Expected behavior
Daily receiving a summary file through a Gmail account (imap.gmail.com:993) in CSV format
Actual behavior
Callback
  • Code: Select all
    [i]23/02/20 03:00:11: Executing "17.IMAP Mail loop"
Workstation
Workaround
  • to install RoboTask Updates
  • to disable TLS 1.0 flag and enable SSL 2 and SSL 3 flags
  • to delete the IMAP Loop action and to add new IMAP Loop action
  • to add IMAP close before
migrador del CSV summary de llamadas por Cola.png (41.03 KiB) Viewed 9321 times
It seems this message is the system error message from Gmail service
Try to limit the loop (see screenshot):
Latest massages are in the end of mail list on IMAP server, so I use reverse order
And you can limit the size of the loop.
