Extracting Text from a File
patelxyz
Post by patelxyz »
Is there anyway you can extract from a text (.txt file) using Robotask, opening the file and choosing the specified text from the file and copying that text and use it to change the name of that file?
If it can be done, I would appreciate an example of Robotask commands I need to use to achieve that.
Thank you.
Jay Patel
I can write an example if you will give me an example of those files and describe in detail what do you want to do.
Thank you for the explanation.
I wrote an example for you and have sent to private e-mail
