Timeout with "Check HTTP Address"
Hey Oleg,
During a task I get an error while using the "Check HTTP address" function. I'm checking a website which initiates a synchronization function. The reply of that website comes after around 30 seconds, which is absolutely correct.
That said, the website is reachable and working perfectly, but....waiting takes quite a while. And....that's correct!
I assume I'm hitting a built-in timeout which I cannot change. The task is stopped with an error. How can I solve this?
Screenshot of the error
