FTP Delete Folder
marcolobaido
FTP Delete Folder
Post by marcolobaido »
Hi, how can I remove a non empty FTP folder?
I: 08/01/2020 14:59:18: Executing "5.FTP Remove Folder"
E: 08/01/2020 14:59:18: FtpRemoveDirectory fails with message: 550 The directory is not empty.
E: 08/01/2020 14:59:18: An error occurred. Step #5 (FTP Remove Folder).
E: 08/01/2020 14:59:18: Task execution is aborted
Re: FTP Delete Folder
You have to remove files in folder first
look at my example
ExternalName=STRING|"Task170"
ID=INTEGER|-220125692
Name=STRING|"Test delete folder"
ActionID=STRING|"A_FTP_LOGON"
Name=STRING|"FTP Log On"
anonymous=STRING|"1"
host=STRING|"localhost"
passive=STRING|"1"
port=STRING|"21"
proxykind=STRING|"0"
useproxy=STRING|"0"
username=STRING|"anonymous"
ActionID=STRING|"A_FTP_DELETEFILE"
Name=STRING|"FTP Delete File"
file=STRING|"/test2/*.*"
ActionID=STRING|"A_FTP_REMOVEFOLDER"
Name=STRING|"FTP Remove Folder"
folder=STRING|"/test2"
