SFTP ascii command
atruban
SFTP ascii command
Post by atruban »
Is there a way to use SFTP to download a file in ascii format? I know by default it's binary, but wasn't sure if there was a way to use a command to change the transfer type.
Re: SFTP ascii command
SFTP actions download files as is.
The downloaded file matches the source file on the server.
