HOUR + 1
bil24884
HOUR + 1
Post by bil24884 »
I have playlist filenames that use date and hour such as Sat1200.alb.
Trying to write NEXT HOUR's playlist to a folder with a different name
Tried creating a variable {PFN} that equals next hour {Hour(+1)} but it does not work. It still shows THIS HOUR and not next hour. Is there an easy way to a variable = next hour instead of this hour?
Re: HOUR + 1
Look at my example
CatID=INTEGER|1251730006
ExternalName=STRING|"Task163"
ID=INTEGER|-121147657
Name=STRING|"add hour"
Name=STRING|"Create local variable ""H"" with value ""{hours}"""
varname=STRING|"H"
varvalue=STRING|"{hours}"
Name=STRING|"Increment variable ""h"""
incement=STRING|"1"
vaiable=STRING|"h"
Name=STRING|"Show ""current hour = {hours}"""
msg0=STRING|"current hour = {hours}"
msg1=STRING|"next hour = {h}"
msgcount=STRING|"2"
bil24884
Re: HOUR + 1
Post by bil24884 »
You made it so easy. Thank you so much for your help!
Re: HOUR + 1
Hey Oleg,
In regard to this question, I'm searching for a solution with does almost the same. When hours = 23 (in the example above) the increment will return 24, which (in my case) should be 00. The leading zero is important.
In the Demo task [DEMO] "TimeIncHours" custom function, the whole {DateTime} is used and will return it as well with the correct amount of hours. However, I only need the hours with the leading zero. The demo task does this part correct, but returns the whole date.
function TimeIncHours(tm, add)
TimeIncHours = DateAdd("h", CInt(add), CDate(tm))
end function
Due to the fact I am a VB / JS n00b, how can I (without using string / regex stuff) adjust the script so that this only returns the hours with a leading zero? The function DateAdd("h",1, Now()) does the same.
Edit
Hour(FormatDateTime(DateAdd("h",1, Now()+1),4)) - :shock: :shock: Did it solved it myself now? WOW! It looks promsising to say at least.
Edit 2:
No, the leading zero is missing. :x
Re: HOUR + 1
...how can I (without using string / regex stuff) adjust the script so that this only returns the hours with a leading zero?
Maybe this? Look at this example
ExternalName=STRING|"Task1474"
ID=INTEGER|-1459948289
Name=STRING|"[DEMO-modified] ""TimeIncHours"" custom function"
StepPause=INTEGER|0
Name=STRING|"Set variable ""TM"" with value ""{DateTime}"""
varname=STRING|"TM"
varvalue=STRING|"{DateTime}"
Name=STRING|"Set variable ""DELTA"" with value ""15"""
varname=STRING|"DELTA"
varvalue=STRING|"15"
Name=STRING|"VB Evaluate"
expression=STRING|"TimeIncHours(""{tm}"", {delta})"
line00000000=STRING|"function TimeIncHours(tm, add)"
line00000001=STRING|"  TimeIncHours = DateAdd(""h"", CInt(add), CDate(tm))"
line00000002=STRING|"end function"
line00000004=STRING|"'logmessage(TimeIncHours(""10:22:35"", ""12""))"
linecount=STRING|"5"
loadfromfile=STRING|"1"
variable=STRING|"newTime"
Name=STRING|"Show ""TimeIncHours result:"""
msg0=STRING|"TimeIncHours result:"
msg2=STRING|"Current time: {tm}"
msg3=STRING|"Delta: {delta}"
msg4=STRING|"New time: {NewTime}"
msg5=STRING|"Only time {Time({NewTime})}"
msg6=STRING|"Only hours {DateTimeToFormat({NewTime},hh)}"
msg7=STRING|"Hours and minutes {DateTimeToFormat({NewTime},hh:mm)}"
msgcount=STRING|"8"
Re: HOUR + 1
Yupz, ofcourse that works perfectly! Thanks.
