Greetings! You made one of the best and easy to use program.
But i confront with some difficulties in easy task.
I use function "copy/move file" - I need to pick up garbage from my desktop, but i cant find any mask to except some extensions.
For example - move all files and folders, except *.lnk
And for some reason it ignores folder. It can move files from folder, but cant move folder with content.
How can i realize that? Thank you!
How to move folder?
Re: How to move folder?
Use Synchronize folders to copy folder with contents and subfolders. This action preserves the folder structure.
If you want to move folder you can remove the source folder. Use Remove folder for this
aleksandr_33
Ok. Thanks for answering!
