Stop task passing Task External Name by parameter
juanlu
Post by juanlu »
Hi Oleg,
Currently, the action "Stop Task" can stop the current running task or a specified task. But the specified task is static, not dynamic.
It would be great if the specified task could take a variable, then it would be dynamic. The variable could be e.g. the task name, external name, id or filename of the task we want to stop.
This would also be a very elegant solution for this: https://robotask.com/forum/viewtopic.php?f=1&t=2157 -> just pass to the child task the task external name from the parent task as an input parameter.
This would make the error-handling so much better, specially in the context of making tasks more modular and reusable.
Kind regards, Juanlu.
juanlu
Re: Stop task passing Task External Name by parameter
Post by juanlu »
Because this is not possible in the GUI, I tried directly putting a variable in the .tsk file. The task was loaded correctly during start up of RoboTask, and it even runs without throwing any errors, but the result of the action Stop Task is "Task not found". When you open the action in the GUI, it just shows Unknown task.
Really a pity.
It looks in the tsk file that what the action is expecting is task id. This can easily be passed from a parent task using {TaskID} (e.g. Parent_Task_ID={TaskID})
Below are my test tasks.
Task for stopping a parent task:
CatID=INTEGER|563781529
ExternalName=STRING|"Stop_parent_task"
ID=INTEGER|1630309343
LocalVariables=STRING|"Parent_Task_ID="
Name=STRING|"Stop parent task"
ActionID=STRING|"A_TASKS_STOP"
Name=STRING|"Stop Task ""!!! Unknown Task !!!"" and terminate it after 60 sec."
killtask=STRING|"1"
taskid=STRING|"{Parent_Task_ID}"
timeout=STRING|"60"
And parent task to be stopped:
ExternalName=STRING|"Parent_task_to_be_stopped"
ID=INTEGER|1990446210
Name=STRING|"Parent task to be stopped"
Name=STRING|"Log Message - Starting..."
message=STRING|"Starting..."
Name=STRING|"Start Task ""Stop parent task"""
parameter0000=STRING|"Parent_Task_ID={TaskID}"
parametercount=STRING|"1"
required=STRING|"1"
taskid=STRING|"1630309343"
wait=STRING|"1"
Name=STRING|"Log Message - Still running!"
message=STRING|"Still running!"
I do have the impression that implementing this change shouldn't be too difficult; and the benefit would be quite big.
You can do this by using VB script
Look at my example below. Save the text of the task to a file and use menu Task->Import to import the task into RoboTask.
ExternalName=STRING|"Task611"
ID=INTEGER|-1725643136
Name=STRING|"Stop task by using variable"
Name=STRING|"Set variable ""EXTNAME"" with value ""TestTaskForStop"""
varname=STRING|"EXTNAME"
varvalue=STRING|"TestTaskForStop"
Name=STRING|"VB Script"
expandvars=STRING|"0"
line00000000=STRING|"nm = RoboTaskApp.ExpandText(""{ExtName}"")"
line00000001=STRING|"logmessage(""Stopping the task '"" + nm + ""'"")"
line00000002=STRING|"RoboTaskApp.stoptask(nm)"
linecount=STRING|"3"
savescript=STRING|"0"
juanlu
Post by juanlu »
Thanks for the reply. Will try that, looks promising.
juanlu
Post by juanlu »
Works perfectly! Thanks a lot!
