Cannot Edit Remote Connection Tasks
TeamGolden
Post by TeamGolden »
Trying to recreate our tasks on a new machine and cannot edit the tasks for some reason. When I click edit, nothing happens. Tested this on a Windows Server 2008 machine and it works fine. Thought it could have been a setup mistake from all the trial and error I've done. Completely removed all of RoboTask and settings and reinstalled. Same issues.
New machine: Windows 10 Pro version 1903
RoboTask version: 7.6.2.988 (currently using the trial)
What I've done:
Installed and started service with default settings.
Created remote connection: localhost, port 5501, credentials are correct.
Tried making new tasks in new directories.
Tasks load as expected but when I click edit, nothing happens. I need the tasks to run under the service so we don't have issues after a restart/log off.
dudede
Re: Cannot Edit Remote Connection Tasks
Post by dudede »
we have the same problem with the new Version 7.6.2.988.
- We can't edit remote tasks
- We can't copy tasks from a remote server to the local workstation
I installed an old version (7.5) to test if it is a problem at our network configuration.
But with 7.5 I can edit/copy/duplicate remote tasks.
So I think there must be a problem with the new version.
If I try to copy a remote task I get this error in my local workstation log:
Unhandled exception: Access violation at address 00549F2B in module 'RoboTask.exe'. Read of address 00000018
If I try to edit a remote task I get this error in my local workstation log:
Unhandled exception: Access violation at address 5003C5A2 in module 'rtl160.bpl'. Read of address 00000018
Hope you can solve this issue with this informations.
Greetings,
Dennis
Thank you for the information.
We'll fix it ASAP
Already fixed. Download fresh copy please
dudede
Post by dudede »
Thank you Oleg for the fast fix :)
