Check for File Exist
Vikram
Post by Vikram »
HI,
How can i check whether a file exist in a particular folder.
Thanks
Vikram
There is FileExists() system variable. You can use construction like this:
Change folder to desired
If {FileExists(FileName.ext)}=true then
   Do something
End if
I can write an example, if needed
Also you can use full path to file. For example:
{FileExists(C:\Program Files\Common Files\Microsoft Shared\Help\dexplore.exe)}
