robotask running tasks list and system uptime
rgonzalez
Post by rgonzalez »
Is it possible to get a list of robotask current running tasks?
Is it possible to get the computer running uptime or date since last reboot?
Thank you.
Re: robotask running tasks list and system uptime
Menu Task->Local running tasks
Look at my example:
CatID=INTEGER|1604865554
ExternalName=STRING|"Task720"
ID=INTEGER|-1754372993
Name=STRING|"show system uptime"
ActionID=STRING|"A_MISC_RUNCONSOLEAPP"
Name=STRING|"Run command-line utility: cmd /c systeminfo | find ""System Boot Time"""
convertansi=STRING|"0"
ifnonzero=STRING|"0"
outputvar=STRING|"out"
params=STRING|"/c systeminfo | find ""System Boot Time"""
program=STRING|"cmd"
saveexitcode=STRING|"0"
saveoutput=STRING|"1"
Name=STRING|"RegExp Match"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"{out}"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"(?i)time:\s+([^,]+),\s*(.+)"
savesubexpression=STRING|"1"
singleline=STRING|"0"
subexpressionpos=STRING|"0"
subexpressionvar=STRING|"result"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"res"
ActionID=STRING|"A_TIMEDIFFERENCE"
Name=STRING|"Time Difference"
datetime1=STRING|"{result(1)} {result(2)}"
datetime2=STRING|"{DateTime}"
format=STRING|"4"
valuekind=STRING|"0"
varname=STRING|"uptime"
Name=STRING|"Show ""{out}"""
msg0=STRING|"{out}"
msg1=STRING|"Up time: {uptime}"
msgcount=STRING|"2"
Read additional information here
rgonzalez
Post by rgonzalez »
Thanks, your example works fine, I was trying to do the same thing but I was missing the /c parameter.
And I would like to get a list of robotask running taks and send that list by email, is that possible?
Look at this example
CatID=INTEGER|1448621252
ExternalName=STRING|"Task631"
ID=INTEGER|-1914646826
Name=STRING|"Get running tasks"
Name=STRING|"VB Script"
expandvars=STRING|"0"
line00000000=STRING|"cnt = RoboTaskApp.TaskCount"
line00000002=STRING|"txt = """""
line00000003=STRING|"for i=0 to cnt-1 step 1"
line00000004=STRING|"  stat = RoboTaskApp.TaskInfoState(i)"
line00000005=STRING|"  if stat = 3 then 'task is running"
line00000006=STRING|"    nam = RoboTaskApp.TaskInfoName(i)"
line00000007=STRING|"    txt = txt + nam + Chr(13) + chr(10)"
line00000008=STRING|"  end if"
line00000009=STRING|"next"
line0000000B=STRING|"RoboTaskApp.SetUserVariable ""RunningTasks"", txt"
linecount=STRING|"12"
savescript=STRING|"0"
Name=STRING|"Show ""Running tasks:"""
msg0=STRING|"Running tasks:"
msg1=STRING|"{RunningTasks}"
msgcount=STRING|"2"
rgonzalez
Post by rgonzalez »
works great! excellent service! 5 stars! :lol:
