Thanks!
Automate Task Import
Hi, is there a way you can automate the import of a group of tasks every certain period of time? (for example every 12 hours)
Thanks!
Thanks!
Re: Automate Task Import
Why would you wanna do that? AFAIK, the imported tasks are always disabled after importing. Do you want to enable them manually every 12 hrs?
