Date format as a {Variable}
george
Post by george »
Hi, I was wondering if there is a way I can insert a variable in date format (for example 2019-13-09), and add or substract days taking that value to use them later.
I know you can do it with the current date: {DateTimeToFormat({DateIncDays(+2)},yyyy/mm/dd)} (adding two days to the current date)
But can it be done with an input variable using any future or past date? :geek:
Thanks
Re: Date format as a {Variable}
If your variable contains some date (in you regional format) you can use VB Evaluate action to calculate new date
Look at mu example:
ExternalName=STRING|"Task630"
ID=INTEGER|-1000589786
Name=STRING|"Add and Subtract days"
Name=STRING|"Set variable ""MYVAR"" with value ""{FormatToDateTime(2014-02-19,yyyy-mm-dd)}"""
varname=STRING|"MYVAR"
varvalue=STRING|"{FormatToDateTime(2014-02-19,yyyy-mm-dd)}"
Name=STRING|"VB Evaluate"
expression=STRING|"DateAdd(""d"", 2, Cdate(""{MyVar}""))"
linecount=STRING|"0"
loadfromfile=STRING|"1"
variable=STRING|"MyVarAdd2"
expression=STRING|"DateAdd(""d"", -2, Cdate(""{MyVar}""))"
variable=STRING|"MyVarMinus2"
message=STRING|"{myvar}; {MyVarAdd2}; {MyVarMinus2}"
Read more about DateAdd function here
george
Post by george »
Works great, thanks Oleg! 8-)
