Setting multiple variables
juanlu
Post by juanlu »
Hi Oleg,
It would be great if we could set multiple variables using just one action. For example, we can this today with the Excel Get Cells, which is cool. Then, it would be great if the Set Variable action had the same feature of entering multiple variable names and its corresponding values.
As of today, if you need to set many variables (e.g. after using regex to read a csv file with many columns), you need to use as many Set Variable actions, which makes the task unnecessarily long and difficult to read.
Kind regards,
Juanlu.
Re: Setting multiple variables
look here how to set to indexed variables in the loop
ExternalName=STRING|"Task318"
ID=INTEGER|2024929902
Name=STRING|"set to multiple variables"
Action14=FOLDER
Name=STRING|"//the source comma-separated string. any number of elements"
comment=STRING|"the source comma-separated string. any number of elements"
Name=STRING|"//output values"
comment=STRING|"output values"
message=STRING|"Soutce = {Source}"
Name=STRING|"Simple Loop"
[Actions\Action12\Params]
begin=STRING|"1"
end=STRING|"{sz}"
variable=STRING|"NUM"
[Actions\Action13\Params]
message=STRING|"var{num} = {var{num}}"
[Actions\Action14]
Name=STRING|"Set variable ""SOURCE"" with value """"1-st value"", ""2-nd value"", ""3-d value"", ""Hello world!!!"""""
varname=STRING|"SOURCE"
varvalue=STRING|"""1-st value"", ""2-nd value"", ""3-d value"", ""Hello world!!!"""
ActionID=STRING|"A_TXT_COOMATEXT"
Name=STRING|"Comma-separated string -> text"
kind=STRING|"0"
line00000000=STRING|"{source}"
lines=STRING|"1"
variable=STRING|"txt"
ActionID=STRING|"A_TXT_NUMBEROFLINES"
Name=STRING|"TXT Number of Lines"
external=STRING|"0"
line00000000=STRING|"{txt}"
variable=STRING|"sz"
Name=STRING|"//set values in the loop"
comment=STRING|"set values in the loop"
begin=STRING|"1"
end=STRING|"{sz}"
external=STRING|"0"
linenum=STRING|"{num}"
variable=STRING|"line"
Name=STRING|"Set variable ""VAR{NUM}"" with value ""{Line}"""
varname=STRING|"VAR{NUM}"
varvalue=STRING|"{Line}"
juanlu
Post by juanlu »
Thanks for your reply.
Your suggestion does not address my original request. I am not talking about setting an array variable, but multiple, different variables.
Think about the scenario where you have multiple global variables used in many different tasks, and one of these tasks is setting those variables. Obviously you don't want to be working with myArray(5) all over the place, but with its own variable that has an intuitive name.
For example, you have information about Employees (e.g. stores in a CSV or a DB). For sure you don't want to be working in multiple different tasks with variables such as Employee(1), Employee(2), Employee(3)... Employee(20), but rather Employee_ID, Employee_Name, Employee_Title, etc. This is something you can easily do today with the Excel Get Cell action today, just with 1 action. If you want to assign variables with Set Variables, you need 20 actions.
