Disable reserved symbols
alex322
Post by alex322 »
I need to emulate keystrokes from clipboard which may contains special symbols as *,#, { , etc.
But RoboTask recognizes them as special. Is there way disable that behavior?
Thanks in advance.
Re: Disable reserved symbols
how to use reserved symbols:
How to simulate reserved symbols: ^ % + # { } ( )
You can do this by using Shift combinations, like this
  • ^ - Shift-6 , i.e. +(6)
    % - Shift-5 , i.e. +(5)
    + - Shift-= , i.e. +(=)
    # - Shift-3 , i.e. +(3)
    { - Shift-[ , i.e. +([)
    } - Shift-] , i.e. +(])
    ( - Shift-9 , i.e. +(9)
    ) - Shift-0 , i.e. +(0)
Also it's possible to use these symbols within braces
This is described in documentation or help file: https://robotask.com/help/index.php?send_keys.htm
also look at my examples
CatID=INTEGER|1075658632
ExternalName=STRING|"Task616"
ID=INTEGER|1561581415
Name=STRING|"Send special chars (1)"
Name=STRING|"Send keys to ""Notepad"""
currentwindow=STRING|"0"
fixedwindow=STRING|"0"
keylayout=STRING|"0"
keys=STRING|"""{^}  "",{(},{)},{#},{{},{}},{%},{+}"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
wincaption=STRING|"Notepad"
2-nd example. You have to replace all special chars
ExternalName=STRING|"Task622"
ID=INTEGER|-282476907
Name=STRING|"Send special chars (2)"
Name=STRING|"Set variable ""OUT"" with value ""^{EOL}%{EOL}+{EOL}#{EOL}{{EOL}}{EOL}({EOL})"""
varname=STRING|"OUT"
varvalue=STRING|"^{EOL}%{EOL}+{EOL}#{EOL}{{EOL}}{EOL}({EOL})"
Name=STRING|"//you have to replace all reserved symbols"
comment=STRING|"you have to replace all reserved symbols"
Name=STRING|"RegExp Replace"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"^"
line00000001=STRING|"%"
line00000002=STRING|"+"
line00000003=STRING|"#"
line00000004=STRING|"{"
line00000005=STRING|"}"
line00000006=STRING|"("
line00000007=STRING|")"
linecount=STRING|"8"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"([\^|\%|\+|\#|\{|\}|\(|\)])"
replacementcount=STRING|"0"
replacemode=STRING|"0"
repline00000000=STRING|"{$1}"
replinecount=STRING|"1"
singleline=STRING|"1"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"out1"
Enabled=INTEGER|0
Name=STRING|"Show ""{out}"""
msg0=STRING|"{out}"
msg1=STRING|"****"
msg2=STRING|"{out1}"
msgcount=STRING|"3"
keys=STRING|"{out1}"
pause=STRING|"20"
release=STRING|"0"
sendkind=STRING|"0"
alex322
Post by alex322 »
Hi Oleg,
It's not working for me.
1. I need to type clipboard content and don't know if it contains special chars.
2. I use free version and regex module isn't available.
alex322
Post by alex322 »
Hi Oleg,
Unfortunately, it's not working for me.
1. I need to type content of clipboard and I can't know if it contains special chars or not.
2. I use Lite version without RegEx module.
you can use system powershell to make necessary replacements
for example, use such command line:
powershell -Command "(get-clipboard) -replace '([\^|\%|\+|\#|\{|\}|\(|\)])', '{$1}' | Out-File -encoding ASCII myFile.txt"
You can use regular expressions in this command-line
You will get the file myFile.txt with necessary replacements as a result.
If system Clipboard doesn't contain some reserved symbols the command will return text without changes.
alex322
Post by alex322 »
Working.
Спасибо Олег.
