Sample script for File Monitor demo 2nd edition HELP
renders
Post by renders »
Hello.. I am trying to use the sample script called, Mail list of new files (File monitor demo) 2-nd edition and am having troubles. I have included my modified version with # for private info.
Basically, I want to monitor 4 folders on our NAS and when a wav file appears, I want to move the file to another folder on another server and then send an email with the name of the file.
Issue is with the file transfer, email section works perfectly..
Any help is appreciated..
Thanks
Rob
CatID=INTEGER|0
ContinueOnError=INTEGER|2
ExternalName=STRING|"Task15"
ID=INTEGER|1839340077
LocalVariables=STRING|"list=,subj="
Name=STRING|"Monitor ProdBox Import"
OnErrorTaskID=INTEGER|-396267805
UnicodeFormat=INTEGER|0
Name=STRING|"File Loop"
date1=STRING|"20120910"
date2=STRING|"20120910"
destvar=STRING|"CFILE"
DuringMinutes=STRING|"1"
file0=STRING|"\\nas-1\Prodbox\Chatham\Import\*.wav"
file1=STRING|"\\nas-1\Prodbox\Sarnia\Import\*.wav"
file2=STRING|"\\nas-1\Prodbox\London\Import\*.wav"
file3=STRING|"\\nas-1\Prodbox\Windsor\Import\*.wav"
filecount=STRING|"4"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
Name=STRING|"Delete File"
Count=STRING|"4"
deletedirs=STRING|"0"
file0=STRING|"\\nas-1\Prodbox\Chatham\Import\*.pkf"
file1=STRING|"\\nas-1\Prodbox\Sarnia\Import\*.pkf"
file2=STRING|"\\nas-1\Prodbox\London\Import\*.pkf"
file3=STRING|"\\nas-1\Prodbox\Windsor\Import\*.pkf"
hidden=STRING|"0"
subdir=STRING|"0"
system=STRING|"0"
ToRecycleBin=STRING|"0"
Name=STRING|"Set variable ""LIST"" with value ""{list}{cfile}{EOL}"""
varname=STRING|"LIST"
varvalue=STRING|"{list}{cfile}{EOL}"
Name=STRING|"Set variable ""SUBJ"" with value ""{SUBJ} {ExtractFileNameNoExt({cfile})},"""
varname=STRING|"SUBJ"
varvalue=STRING|"{SUBJ} {ExtractFileNameNoExt({cfile})},"
ActionID=STRING|"A_STR_TRIM"
Name=STRING|"STR Trim"
custom=STRING|"1"
customchar=STRING|","
eol=STRING|"0"
lead=STRING|"1"
source=STRING|"{subj}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
variable=STRING|"subj"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
source=STRING|"{list}"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
variable=STRING|"list"
Name=STRING|"Send Email"
attachcount=STRING|"1"
auth=STRING|"1"
charset=STRING|"iso-8859-1"
from=STRING|"#@#.com"
host=STRING|"#.com"
html=STRING|"0"
msg0=STRING|"New files imported"
msg1=STRING|"{list}"
msgcount=STRING|"2"
password=STRING|"#"
port=STRING|"25"
priority=STRING|"1"
receipt=STRING|"0"
SSL=STRING|"0"
subject=STRING|"ProdBox Files Imported: {subj}"
to=STRING|"#@#.com"
user=STRING|"#@#.com"
file2=STRING|"\\nas-1\ProdboxLondon\Import\*.wav"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"O:\AudioImport\"
f_count=STRING|"1"
file0=STRING|"{cfile}"
hidden=STRING|"0"
ifexists=STRING|"0"
move=STRING|"1"
rename=STRING|"0"
subdir=STRING|"0"
system=STRING|"0"
Name=STRING|"File Monitor"
UniqueID=INTEGER|-60837805
chg=STRING|"0"
chga=STRING|"1"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"0"
folder1=STRING|"\\nas-1\Prodbox\Chatham\Import\"
folder2=STRING|"\\nas-1\Prodbox\Sarnia\Import\"
folder3=STRING|"\\nas-1\Prodbox\London\Import\"
folder4=STRING|"\\nas-1\Prodbox\Windsor\Import\"
foldercount=STRING|"4"
incmask=STRING|"*.wav"
interval=STRING|"10"
listmode=STRING|"2"
mon_files=STRING|"1"
mon_folders=STRING|"0"
new=STRING|"1"
newlist=STRING|"c:\new_files.txt"
pass=STRING|"0"
passmode=STRING|"1"
required=STRING|"0"
saveresults=STRING|"0"
subfolders1=STRING|"0"
subfolders2=STRING|"0"
subfolders3=STRING|"0"
subfolders4=STRING|"0"
Re: Sample script for File Monitor demo 2nd edition HELP
But what is the problem? Maybe some log file with error messages? I don't see fatal problems.
But I have two notes:
1. I think that you need to move the step #10 (delete file) out of the loop. Place it after EndLoop
2. Maybe it's necessary to put Wait for File action before you try to move it. The file can be locked by another process. You have to determine the timeout manually.
Look at the corrected task:
CatID=INTEGER|1040932817
ExternalName=STRING|"Task628"
Name=STRING|"Monitor ProdBox Import (2 ver)"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
f_count=STRING|"1"
hidden=STRING|"0"
ifexists=STRING|"0"
move=STRING|"1"
rename=STRING|"0"
subdir=STRING|"0"
system=STRING|"0"
[Actions\Action12\Params]
Count=STRING|"4"
hidden=STRING|"0"
subdir=STRING|"0"
system=STRING|"0"
custom=STRING|"1"
eol=STRING|"0"
lead=STRING|"1"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
custom=STRING|"0"
eol=STRING|"1"
lead=STRING|"1"
spaces=STRING|"1"
tabs=STRING|"1"
trailing=STRING|"1"
auth=STRING|"1"
host=STRING|"#.com"
html=STRING|"0"
msgcount=STRING|"2"
password=STRING|"#"
port=STRING|"25"
priority=STRING|"1"
receipt=STRING|"0"
SSL=STRING|"0"
to=STRING|"#@#.com"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
ActionID=STRING|"A_FILE_WAIT"
Name=STRING|"Wait accessibility of the file ({cfile}) for 60 seconds"
filename=STRING|"{cfile}"
mode=STRING|"0"
timeout=STRING|"60"
UniqueID=INTEGER|-1709046769
chg=STRING|"0"
chga=STRING|"1"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"0"
listmode=STRING|"2"
new=STRING|"1"
pass=STRING|"0"
passmode=STRING|"1"
required=STRING|"0"
