How to add task between applications??
edusa2ooo
Post by edusa2ooo »
I have to edit an excel file and delete some columns, but I cannot find the right commands nor using mouse strokes as it doesn't remember the position.
Thanks.
Re: How to add task between applications??
Excel actions can get cells from Excel document or put some data to Excel document
If you want to do some advanced actions you have top use VB script and learn Excel object structure
Look at my example please (see below)
CatID=INTEGER|1075658632
ExternalName=STRING|"Task613"
ID=INTEGER|927607580
Name=STRING|"Delete column"
Name=STRING|"VB Script"
expandvars=STRING|"0"
line00000000=STRING|"Sub DeleteColumn(clmn)"
line00000001=STRING|"    set app = CreateObject(""Excel.Application"")"
line00000002=STRING|"    app.Visible = true"
line00000003=STRING|"    set book = app.workbooks.Open(""C:\Users\olegyershov\Documents\test.xls"")"
line00000004=STRING|"    'Messagebox(""Press OK"")"
line00000005=STRING|"    app.Columns(clmn +"":""+clmn).Select"
line00000006=STRING|"    app.Selection.Delete Shift=xlToLeft"
line00000007=STRING|"    'Messagebox(""Press OK"")"
line00000008=STRING|"    book.save"
line00000009=STRING|"    app.quit"
line0000000A=STRING|"End Sub"
line0000000C=STRING|"DeleteColumn(""E"")"
linecount=STRING|"14"
savescript=STRING|"0"
the script is
    set app = CreateObject("Excel.Application")
    app.Visible = true
    set book = app.workbooks.Open("C:\Users\olegyershov\Documents\test.xls")
    app.Columns(clmn +":"+clmn).Select
    book.save
    app.quit
End Sub
DeleteColumn("E")
