Personal - Commercial License
tchangth
Post by tchangth »
I wanted to upgrade from Personal to Commercial license. Should I just key in the Commercial license and it would take effect immediately? Or should I uninstall the personal license first and then reinstall Robotask again and then apply the commercial license ? thx
Re: Personal - Commercial License
You should apply this key. Use "Input Registration key" utility (see screenshot)
Or use InputRegKey.exe from RoboTask's folder
Next input your new key, apply it and restart RoboTask.
