Reading the text
dondada
Reading the text
Post by dondada »
How do I save the text in the 2nd line 5th column of a .csv file to a variable and then write the variable to a different text file? I can do everything except getting the value on the 2nd line 5th column.
Please help! Thanks
Reading the text
You can access to a part of user variable, which contains a comma-separated string so:
{My_var(0)}
{My_var(1)}
and so on. Index number is beginning from 0. I advise you to use "Delimited variable" action to normalize your delimited string. This action can transform any delimited strings to standard state.
Delimited variable action is in variables plugin.
dondada
Reading the text
Post by dondada »
Could you please write a task that shows how. Thanks!
Reading the text
Of course, see below
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|565106205
ExternalName=STRING|"Task293"
ID=INTEGER|1714365089
Name=STRING|"Delimited strings demo"
Name=STRING|"Text Loop"
destvar=STRING|"C_LINE"
line0=STRING|"Fist string; First Value; 125"
line1=STRING|"""Second string""; second value; 300"
linecount=STRING|"2"
sourcetext=STRING|"1"
Name=STRING|"Delimited Variable"
colon=STRING|"0"
comma=STRING|"0"
other=STRING|"0"
quote=STRING|"0"
semocolon=STRING|"1"
space=STRING|"0"
spaceasone=STRING|"0"
string=STRING|"{c_Line}"
tab=STRING|"0"
variable=STRING|"c_line1"
Name=STRING|"Show ""Original string """
msg0=STRING|"Original string "
msg1=STRING|"{c_line}"
msg3=STRING|"Normalized string"
msg4=STRING|"{c_line1}"
msg6=STRING|"Value0 = {c_line1(0)}"
msg7=STRING|"Value1 = {c_line1(1)}"
msg8=STRING|"Value2 = {c_line1(2)}"
msgcount=STRING|"9"
dondada
Reading the text
Post by dondada »
I tried the task you wrote and it did not work despite all the modifications that I could think of trying! I emailed you the actual csv file that I am working with. Please help me make it work. Thanks!
Reading the text
I haven’t received any CSV files.
Please, send again and describe in detail, what do you want to do.
Reading the text
See task below. It reads your CSV file from c:\new.csv. Remember, that number of fields begins from 0, therefore 5-th field have a number 4. If you don't understand anything, feel free to ask again.
;* Do not edit!       *
ExternalName=STRING|"Task297"
ID=INTEGER|197615729
Name=STRING|"5-th field on 2-nd line"
Name=STRING|"Set variable ""EMAIL_FROM_CSV"" with value """""
varname=STRING|"EMAIL_FROM_CSV"
Name=STRING|"Set variable ""CSV_LINE_NUMBER"" with value ""1"""
varname=STRING|"CSV_LINE_NUMBER"
varvalue=STRING|"1"
destvar=STRING|"CSV_LINE"
file=STRING|"C:\new.csv"
linecount=STRING|"0"
sourcetext=STRING|"0"
type=STRING|"1"
value1=STRING|"{csv_line_number}"
value2=STRING|"2"
Name=STRING|"Set variable ""EMAIL_FROM_CSV"" with value ""{csv_line(4)}"""
varvalue=STRING|"{csv_line(4)}"
Name=STRING|"Increment variable ""csv_line_number"""
incement=STRING|"1"
vaiable=STRING|"csv_line_number"
Name=STRING|"Show ""Extacted email is:"""
msg0=STRING|"Extacted email is:"
msg1=STRING|"{email_from_csv}"
msgcount=STRING|"2"
Reading the text
Please, pay attention that you must turn on "Expand variable value" checkbox when you assign the value to EMAIL_FROM_CSV variable.
