Synchronize folders tage long time
jwal75
Post by jwal75 »
Good afternoon,
I created a simple task that sync. two network folders uni-directional.
When i run this task the task runs for a long time. I don't see anything happening.
When running a command prompt with robocopy.exe /mir it takes less then a minute to process.
the Source folder contains around 50.000 items. but most of them are already in the destination. it should only sync the files added by today.
Is there anything that i do wrong?
Re: Synchronize folders tage long time
We have investigated the problem.
We found a way to optimize and speed up the process, but we need to make some tests.
The new release (patch) will be soon.
jwal75
Post by jwal75 »
Thanks Oleg,
Looking forward to see the change available!
Jeroen
Download and test fresh copy with corrections: https://robotask.com/downloads/RobotaskSetup.exe
