Text files reading 2nd line
dondada
Post by dondada »
I wrote a task to read the 2nd line of every file in a folder and append the 2nd line to a different file. It needs to do this for every file in the folder. The problem is it only does it for the 1st two files. Please Help me fix the problem. Thanks!
Here is the task
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|1261164818
ExternalName=STRING|"Task7"
ID=INTEGER|1166573864
Name=STRING|"(1) Combine New Member .csv files for import to Quickbooks"
Name=STRING|"File Loop"
date1=STRING|"20050731"
date2=STRING|"20050731"
destvar=STRING|"{NEWMEMBER}"
file0=STRING|"C:\ICARE\New Members to Import to QuickBooks\*.csv"
subdirs=STRING|"0"
timesize=STRING|"0"
Name=STRING|"Text Loop"
destvar=STRING|"{LINE}"
file=STRING|"{NEWMEMBER}"
linecount=STRING|"0"
sourcetext=STRING|"0"
Name=STRING|"Create text file C:\ICARE\GOPD\Quickbooks Import\QB_IMPORT_FILE.csv"
fileexists=STRING|"1"
filname=STRING|"C:\ICARE\GOPD\Quickbooks Import\QB_IMPORT_FILE.csv"
line0=STRING|"{LINE}"
Try this task (see below). If you want to process only 2-nd line in each file you must use some counter (in task there is Line_Num variable) and insert "If … then" action into text loop.
I've added "Minimize RoboTask" into beginning of the task, because loops work quickly, when RoboTask is minimized.
;* Do not edit!       *
CatID=INTEGER|1614811947
ExternalName=STRING|"Task290"
ID=INTEGER|1984238025
Name=STRING|"Combine New Member .csv files for import to Quickbooks"
ActionID=STRING|"A_ROBOTASK_MINIMIZE"
Name=STRING|"Minimize RoboTask"
ActionID=STRING|"A_ROBOTASK_RESTORE"
Enabled=INTEGER|0
Name=STRING|"Restore RoboTask"
subdirs=STRING|"0"
timesize=STRING|"0"
Name=STRING|"Set variable ""LINE_NUM"" with value ""1"""
varname=STRING|"LINE_NUM"
varvalue=STRING|"1"
line0=STRING|"{TextFile({newmember})}"
type=STRING|"1"
value1=STRING|"{Line_Num}"
value2=STRING|"2"
Name=STRING|"Increment variable ""Line_Num"""
incement=STRING|"1"
vaiable=STRING|"Line_Num"
