Tab order scheduler time window
Oleg!
In the Triggering Events --> Scheduler window --> Add time, the TAB order is somehow confusing.
By default, the focus is on the hour. When you tab, you go to "Now". I think it's better to move it first to the minute field, and the second field afterwards.
Another solution can be that the program jumps itself to the next field, as long as you type. So filling in "194550" results in 19:45:50 automatically.
Screenshot of the affected window.
Re: Tab order scheduler time window
This is standard time editor element.
Yes, if you press TAB then focus goes to next element of dialog.
If you want to move to minutes press RightArrow key or press ":"
Type 19:45:50 with ":" symbol or press RightArrow to move to minutes and seconds
Ok. Clear. Thanks for the quick reply.
