File Monitor Parameters
renders
Post by renders »
Hello.. I have a simple file monitor running which basically watches a folder for new wav files, copies them to another folder and deletes the original. I would like to have an email sent out everytime the transfer takes place with the name of the file that was moved. I tried adding a filename variable to the Pass as Parameters but the email does not seem to catch this..
What is the best way to handle this?
Thanks
Re: File Monitor Parameters
Maybe you do something wrong.
Look at my example, it works.
CatID=INTEGER|1040932817
ExternalName=STRING|"Task19"
ID=INTEGER|-1021423029
Name=STRING|"Show ""{files}""..."
Name=STRING|"Show ""New files:"""
msg0=STRING|"New files:"
msg1=STRING|"{files_n}"
msg3=STRING|"Deleted files:"
msg4=STRING|"{files_d}"
msg6=STRING|"Changed files:"
msg7=STRING|"{files_e}"
msgcount=STRING|"8"
Name=STRING|"File Monitor"
UniqueID=INTEGER|-1672530239
chg=STRING|"1"
chga=STRING|"1"
chglistparameter=STRING|"Files_e"
chgsl=STRING|"1"
chgsm=STRING|"1"
chgtl=STRING|"1"
chgtm=STRING|"1"
del=STRING|"1"
dellistparameter=STRING|"files_d"
folder1=STRING|"D:\incoming"
foldercount=STRING|"1"
incmask=STRING|"*.*"
interval=STRING|"10"
listmode=STRING|"1"
mon_files=STRING|"1"
mon_folders=STRING|"0"
new=STRING|"1"
newlistparameter=STRING|"files_n"
onelistparameter=STRING|"files"
pass=STRING|"1"
passmode=STRING|"2"
required=STRING|"1"
saveresults=STRING|"0"
subfolders1=STRING|"1"
Could you send you send your task to me in private message or to direct email oleg(at)robotask.com?
renders
Post by renders »
Sorry for the long delayed response..
Your example worked perfectly for my needs..
Thank you.
