RoboTask 7.4 has been released
Locked
New version of RoboTask is ready for download. Download and try RoboTask 7.4 now
What's new in RoboTask 7.4:
Legend
[+] Feature added
[-] Bug fixed
[*] Modified or improved[/i]
+ Added Chromium plugin. This plugin is designed to replace obsolete engine in “Web Documents” plugin.
New actions:
  • + CEF Fill Web Form
    + CEF Web Page Information
    + CEF Click Link
    + CEF Wait for Done
    + CEF Page Snapshot
+ Added the ability to edit the name of the triggering events.
+ Added the internal error processing for SSL FTP actions
+ Added tab-separated TXT and XML formats for “Excel save as” action
+ Added an entry in the system log about connecting and disconnecting a remote client.
* Improved screenshot actions. Now it can take a snapshot from any monitor.
* Improved macro-recorder module. Removed problems with unicode text.
* Replaced folder selection dialogs in the entire application.
* Improved “Send command” action. Now you can save the amount of started tasks into variable
* Many other optimizations, improvements and bug fixes.
Locked
