Spaces in SFTP Folder Location
paraffin
Post by paraffin »
Hi
I am working with an SFTP folder structure that has spaces which I cannot change.
I am using a variable that picks up this location on the SFTP File Loop that seems to accept the 'space' and moves onto downloading the file but I also want to delete the file on the SFTP server but the delete function interprets the space as the end of the folder string and fails.
I have tried using " and ' to encapsulate the SFTP Folder path but this stops it working altogether.
Any help appreciated
paraffin
Re: Spaces in SFTP Folder Location
Post by paraffin »
I found the solution, on the SFTP Delete I had to encapsulate the Variable in " " to allow it to work which is different how the download works.
What names do you mean?
with spaces in name like this: name with space.txt
Or does file (or folder) name have leading or trailing spaces?
Provide an example please.
paraffin
Post by paraffin »
HI Oleg
I have a task setup and with the following variables
SFTPFOLDER=/users/EI02 Export/UAT
FILESEARCH=*.*
FILETRANSFER=
LOCALFOLDER=E:\Data Import\File Import
The SFTP File Loop uses the first 2 to find files like this {SFTPFOLDER}/{FILESEARCH} it then puts the files in this local variable FILETRANSFER
In the SFTP Download, I use {FILETRANSFER} and {LOCALFOLDER} which works
In the SFTP Delete I need to use "{FILETRANSFER}" and this then works but as {FILETRANSFER} it doesn't handle the space in "/users/EI02 Export/UAT"
If you need more info then let me know
Yes, of course you have to use quotes if the name contains spaces. Otherwise the command think that you use the list of files
BTW: You can use quotes always.
Maybe we need to make some improvements in order to avoid such problem. I wrote this into our ToDo
paraffin
Post by paraffin »
Thanks Oleg
It could just be that the help is updated as it doesn't mention how to manage special characters
