File Loop Variable
jkvandalen
File Loop Variable
Post by jkvandalen »
1st time user ... evaluating the product.
I'm creating a task that must login to FTP, go to a local directory and upload all file (i.e. *.csv).
Everything is working ok other than the File Loop.
The Loop is defined as:
Search for Files: {FROMDIRECTORY}\*.CSV
{FROMDIRECTORY} was setup previously
Assign Current Filename to Variable: {FILETOUPLOAD}
{FILETOUPLOAD} is not being set ... is always empty. I did wrote to a text file inside the loop and see the value for {FROMDIRECTORY} 4 times (there are 4 files in the directory) but the {FILETOUPLOAD} never gets set.
Any idea on what I'm doing wrong? Exported task attached
Thanks in advance.
Re: File Loop Variable
Use FILETOUPLOAD (without braces) as name of variable
Like this - look at the example below
CatID=INTEGER|742360135
ExternalName=STRING|"Task534"
ID=INTEGER|-432359209
Name=STRING|"file loop example"
ToLog=INTEGER|2
Name=STRING|"File Loop"
date1=STRING|"20190305"
date2=STRING|"20190305"
destvar=STRING|"FILE"
DuringMinutes=STRING|"1"
file0=STRING|"{TempDir}\*.*"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
message=STRING|"{file}"
If you use variable in some expression you highlight the variable name. So you have to use braces "{}"
When you want to specify variable name to save some value - just specify the name only.
The problem is that you can specify a variable name using other variables in the expression. For example: MyVar{num}
