Script with SSH2
Ajornet
Script with SSH2
Post by Ajornet »
I want to automatize some tasks via telnet with my web server : download data, manipulate them and upload the results.
Telnet is under SSH2 with a server-key, and I don't see how to establish the connection.
Can you help me.
PS : I'm in my trial period.
Script with SSH2
Can you connect via telnet manually? If it possible I think that you are able to create a task with "Send keystrokes" action.
Ajornet
Script with SSH2
Post by Ajornet »
Yes, I can connect manually via telnet, but RT is waiting the end of
the elementary task "lauch the SSH client" before sending the keys.
Daniel
Ajornet
Script with SSH2
Post by Ajornet »
Finally, I will work with putty-psftp and their script files.
It's very good with RT.
Thanks
