Regex get just the first match at row
manxasp
Post by manxasp »
hiho,
I need to collect only the first match of each line
i have this:
0000000A123456789 908jej0e38h83he 29h8e2e92 e928je2je9j2 2232 0987654A154548759 6484e3
0000000N123458745 3nn88he83he9j3 e039je93ej 39ej309je903 3333 0215487A458745587 587422
i want this:
123456789
123458745
I already tried to use
[A|N](/d/d/d/d/d/d/d/d/d/d)
but return:
123456789
154548759
123458745
458745587
Re: Regex get just the first match at row
Look at my example below. It works
ExternalName=STRING|"Task250"
ID=INTEGER|1311298238
Name=STRING|"Get 1-st occurrence at the line"
Name=STRING|"Set variable ""TXT"" with value ""0000000A123456789 908jej0e38h83he 29h8e2e92 e928je2je9j2 2232 0987654A154548759 6484e3{EOL}0000000N123458745 3nn88he83he9j3 e039je93ej 39ej309je903 3333 0215487..."""
varname=STRING|"TXT"
varvalue=STRING|"0000000A123456789 908jej0e38h83he 29h8e2e92 e928je2je9j2 2232 0987654A154548759 6484e3{EOL}0000000N123458745 3nn88he83he9j3 e039je93ej 39ej309je903 3333 0215487A458745587 587422"
Name=STRING|"Set variable ""RESULT"" with value """""
varname=STRING|"RESULT"
Name=STRING|"Text Loop"
destvar=STRING|"LINE"
line0=STRING|"{txt}"
sourcetext=STRING|"1"
Name=STRING|"RegExp Match"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"{line}"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"[A|N](\d\d\d\d\d\d\d\d\d)"
savesubexpression=STRING|"1"
singleline=STRING|"1"
subexpressionpos=STRING|"0"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"found"
value1=STRING|"{found}"
Name=STRING|"Set variable ""RESULT"" with value ""{result}{expr(1)}{EOL}"""
varvalue=STRING|"{result}{expr(1)}{EOL}"
Name=STRING|"Show ""{result}"""
msg0=STRING|"{result}"
Let me know if you have some questions.
